bigboss Posted November 6, 2008 Report Share Posted November 6, 2008 (edited) hi, im having some electric problems with my 2001 vw polo saloon. The driver side electric window is not working at all, if you press the button nothing happens. ive been reading around and im assuming its the "window regulator" gone faulty however that is a complete guess. any ideas and advice will be much appreciated+++ also, when i lock the car using the remote (ie remote central locking) all the doors lock, but when opening again, the driver's side door does not open. i have no clue why this is, again any ideas and advice much appreciated. Thanks in advance! (maybe the problems are linked since they are both on the same door???) Edited November 6, 2008 by bigboss Quote Link to comment Share on other sites More sharing options...
mb Posted November 10, 2008 Report Share Posted November 10, 2008 Might be the switches, remove the drivers panel & swap the switches over then try again. Not sure if connected but I would start with the switch panel. Quote Link to comment Share on other sites More sharing options...
