marcmu Posted January 1, 2004 Report Share Posted January 1, 2004 Hi all ... I have a question that I hope someone can help me with ... I have a 89 Alfa 75 with a 3 litre V6 ... how many bar of oil pressure should it show on the gauge ... it shows about 4 bar when cold and drops to 2 bar @ about 3000 rpms once the engine warms up ... but at idle it drops away to almost not register on the gauge ... is this normal or what pressure should I expect it to show ... Thanks for any help / advice U can offer ... Regards Marcus Link to comment Share on other sites More sharing options...
Sven Posted January 1, 2004 Report Share Posted January 1, 2004 Hi Alfanut, welcome to the forum! IIRC the pressures should not fall below 3 bar on idle (ideally). The reason may well be a faulty 'sender'. Alfa's are somewhat notorious for this, so I'd check this first before starting to worry... Link to comment Share on other sites More sharing options...
marcmu Posted January 2, 2004 Author Report Share Posted January 2, 2004 Thanks 4 your reply ... will check or replace the sender ... does my car also have a check valve which may be stuck or not seating properly... Regards Marcus Link to comment Share on other sites More sharing options...
alfa164 Posted November 5, 2004 Report Share Posted November 5, 2004 Here's an easy fix for the sender: http://www.digest.net/alfa/FAQ/164/forum2/DCForumID2/2902.html Link to comment Share on other sites More sharing options...
shitbmxrider Posted November 12, 2004 Report Share Posted November 12, 2004 eeeh....at idle, when warm, my oil pressure gauge is readin about 1bar...and rises and falls with the revs as it does Link to comment Share on other sites More sharing options...
Professor Posted November 26, 2004 Report Share Posted November 26, 2004 Hi Official from handbook Same for 75 TS and 3.0 Hot oil pressure Idling - Min 0.5 Bar Top Speed - Min 3.5 Bar My 75TS runs about 1 - 1.5 bar at idle and 4-5 bar at speed All the manual oil pumps on these cars run a pressure relief valve so u will get a rising rate from idle to a max pressure at about 4000 rpm. From there on the relief valve will be open and max pressure maintained. If the relief valve is not working the the pressure would continue to rise resulting in engine damage (there is such a thing as too much) and oil bypassing seals etc. You will only get constant pressures from dry sump systems on racecars. Anything above the .5 bar at idle is ok. Below this your oil pressure warning light will come on. There is likely to be a seperate sender for oil pressure warning light and gauge as a backup system. Link to comment Share on other sites More sharing options...
Mollox Posted November 26, 2004 Report Share Posted November 26, 2004 Welcome Professor! And thanks for the useful technical input Hope you enjoy Tyresmoke. Link to comment Share on other sites More sharing options...
Ritey Posted November 26, 2004 Report Share Posted November 26, 2004 Welcome Professor Great first post Link to comment Share on other sites More sharing options...
