ghl Posted May 14, 2009 Report Share Posted May 14, 2009 passat 2006 back doors will not open from inside or outside all other doors ok any help please and can central lockin workin and child locks are on so wont be able to open from inside anyway any help please as not safe with kids in car if cant open doors. thanks. Link to comment Share on other sites More sharing options...
rmv Posted May 15, 2009 Report Share Posted May 15, 2009 Hi, no doubt you will have seen the threads on the wet carpets (rear passenger n/s) and the effects thereof......just see if the rear carpets are wet??? Might be affecting the ECM located under the carpet in the front passenger area n/s....water leaks occur usually from the pollen filter housing SEAL (foam seal) and runs down inside into ECM area and then to lowest position being the rear passenger area. Run thro' the other threads as I recall some of the central locking is linked to the ECM ?? Good Luck! Link to comment Share on other sites More sharing options...
dave r Posted January 4, 2010 Report Share Posted January 4, 2010 passat 2006 back doors will not open from inside or outsideall other doors ok any help please and can central lockin workin and child locks are on so wont be able to open from inside anyway any help please as not safe with kids in car if cant open doors. thanks. Hello , I have the same problem with one of our doors the child lock is turned on please confirm how you resolved this problem thank you dave r Link to comment Share on other sites More sharing options...
ghl Posted January 14, 2010 Author Report Share Posted January 14, 2010 Had to leave into garage as they had to strip out pannel on doors and replace some kind of catch (thats what they said) Link to comment Share on other sites More sharing options...
Blodgie Posted March 7, 2010 Report Share Posted March 7, 2010 I have the same problem with one rear door. Childlock is on and the central locking will not operate the dooe. MOT is due on Tuesday (4 years old), does anybody know if the car will fail the MOT over this issue if not resolved? Link to comment Share on other sites More sharing options...
