valleys caveman Posted June 5, 2009 Report Share Posted June 5, 2009 Hi everyone, ive a problem with my passat tdi 2003, every now and again the speedo stops working which also effects the fuel guage making it beep every 5 seconds or so, and indicates theres no fuel (tank is half full) any ideas lads? Thanks Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2009 Report Share Posted June 5, 2009 Hmm, sounds like a dodgy instrument cluster to me. I've replaced a couple of these but not on Passats. The TT instrument clusters tend to fail a lot as do Skoda Octavia ones. Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 Thanks for the reply mate. Problem happened last year for a day or two, but last few days its happened neally everytime ive been in car. Can also hear a noise coming from glovebox, it sounds like a cd player trying to load a cd unsuccesfully (is this where ECU is?) Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 thanks mate Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 also got a noise cming from glovebox (sounds like a cd that wont load, a sort of scratchy noise) could this be the ECU ? Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2009 Report Share Posted June 5, 2009 No the ECU is under the bonnet where the wipers are. Weird noise though! Do you have climate control or manual air con? Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 No the ECU is under the bonnet where the wipers are. Weird noise though! Do you have climate control or manual air con? Ive got climate control mate. Inside the glovebox is a nozzle type thingy, might be climate control re-gas. It maybe a coincidence but the speedo played up on the hottest day last year. Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2009 Report Share Posted June 5, 2009 No idea what that valve is but the speedo playing up when it's hot is quite common as the cluster heats up and everything expands which will show up a dry solder joint/damaged component or other similar fault. Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 Cheers Shark, i drove it this morning and it was fine, weather is cold and rainey in south Wales today (for a change, lol) Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2009 Report Share Posted June 5, 2009 No problem Link to comment Share on other sites More sharing options...
valleys caveman Posted June 5, 2009 Author Report Share Posted June 5, 2009 Is it a easy fix? how much would it cost (roughly) to sort it out (in a garage) Link to comment Share on other sites More sharing options...
shark_90 Posted June 5, 2009 Report Share Posted June 5, 2009 Depends. I usually do dashboard swaps for £65 if you supply the dash. Best place to get one is a breakers. A new dash is £500+ and a dealer won't fit a 2nd hand dash, although I am quite happy to Link to comment Share on other sites More sharing options...
