kirium225 Posted June 14, 2009 Report Share Posted June 14, 2009 Any recommendations. Every time i buy some wheel cleaner i dont get very good results, brake dust is something that most products cannot shift........ Help appreciated. Link to comment Share on other sites More sharing options...
OGWT Posted June 14, 2009 Report Share Posted June 14, 2009 P21S Gel or Liquid Wheel Surface Cleaner (Green) originally developed in 1976 by a German chemist; a water-based, (non-acid) pH balanced detergent that provides terrific cleaning and guarantees not to damage painted, clear-coated, or anodized wheels P21-S Wheel Cleaner (Felgen-Reiniger) Power Gel (Red) – manufacturers approved way to remove stubborn corrosive brake dust and road grime from alloy wheels. Safe, pH controlled, formula is guaranteed not to harm any type of road wheel, braking system or other automotive surface, works safely and effectively on every type of wheel and coating, removes brake pad adhesive and sequestered metal brake dust safely - Performance Motor care or Frost Auto Restoration Techniques Link to comment Share on other sites More sharing options...
kirium225 Posted June 14, 2009 Author Report Share Posted June 14, 2009 Is it available off the shelf or mail order..... Link to comment Share on other sites More sharing options...
wyliss Posted June 14, 2009 Report Share Posted June 14, 2009 P21S Gel or Liquid Wheel Surface Cleaner (Green) originally developed in 1976 by a German chemist; a water-based, (non-acid) pH balanced detergent that provides terrific cleaning and guarantees not to damage painted, clear-coated, or anodized wheels P21-S Wheel Cleaner (Felgen-Reiniger) Power Gel (Red) – manufacturers approved way to remove stubborn corrosive brake dust and road grime from alloy wheels. Safe, pH controlled, formula is guaranteed not to harm any type of road wheel, braking system or other automotive surface, works safely and effectively on every type of wheel and coating, removes brake pad adhesive and sequestered metal brake dust safely - Performance Motor care or Frost Auto Restoration Techniques Couldnt agree more with this product. As a general weaker one, Bilberry. Link to comment Share on other sites More sharing options...
steelwind101 Posted June 15, 2009 Report Share Posted June 15, 2009 There avalible only online as far as i know. Your best weekly cleaner is probably car shampoo! After using P21s etc. put some sealant on your alloys and then that should keep them from getting getting to much brake dust bonded and keep cleaning costs down. Link to comment Share on other sites More sharing options...
