Longing for a saloon Posted June 30, 2009 Report Share Posted June 30, 2009 First post here and hoping someone can give me some advice. Recently my 54 Reg Passat Trendline 100 has had the emissions workshop message appear. It's not 100% of the time but it's more often than not. Should I be calling the bank manager for an extension to the overdraft? I've taken a quick look around the forums here and see that some people have VAGCOM software and can hook this up with the right kind of cable. As I will be keeping the car for the next 3-4 years, would this be money well spent and has anyone an idea of costs? Link to comment Share on other sites More sharing options...
Mook Posted July 1, 2009 Report Share Posted July 1, 2009 Welcome to Tyresmoke You can buy VCDS (formerly VAG-COM) for about £300 IIRC - details and distributors are on the Ross-Tech site Ross-Tech: Home and you can buy it via one of their distributors Ross-Tech: Distributor List but any independent VW specialist should be able to tell you what's up. The Emissions Workshop message doesn't always mean your catalytic converter is FUBARd - it can be lots of things from a coil pack to the lambda probe, to the cat. HTH Link to comment Share on other sites More sharing options...
ajnabi Posted September 1, 2009 Report Share Posted September 1, 2009 Had this on my 54 Passat TDi 130 Sport. I used to get this warning off and on too.. Most of the time with cold starts not after a long drive! VAGCOM reported Engine Coolant Temp Sensor. Replaced ... all good. Coolant Temp. Sensor 059 919 501 A approx. 25.00 Old is black ... new(above) is green. Hope this helps. Link to comment Share on other sites More sharing options...
