markos67 Posted August 24, 2009 Report Share Posted August 24, 2009 I changed the Nav plus head unit in my A4 cabrio earlier this year as the original developed a cd reader problem. The replacement was a used part from an A4 saloon which was sold as fully functional but I can't get the front speakers to work. Does anyone have any idea if it may just be a coding tweak needed in vag com & if so what it is?!! cheers. Link to comment Share on other sites More sharing options...
PetrolDave Posted August 24, 2009 Report Share Posted August 24, 2009 I changed the Nav plus head unit in my A4 cabrio earlier this year as the original developed a cd reader problem. The replacement was a used part from an A4 saloon which was sold as fully functional but I can't get the front speakers to work. Does anyone have any idea if it may just be a coding tweak needed in vag com & if so what it is?!! cheers. Is it an RNS-D (CD based) or an RNS-E DVD based? They both say Audi Navigation plus on the front panel! If it's an RNS-E check whether it's coded for Bose and if the Bose pin is grounded. An A4 saloon/Avant RNS-E will 100% work in an A4 cabrio. Link to comment Share on other sites More sharing options...
markos67 Posted August 25, 2009 Author Report Share Posted August 25, 2009 Hi, it's the RNS-D! Not BOSE. Link to comment Share on other sites More sharing options...
PetrolDave Posted August 25, 2009 Report Share Posted August 25, 2009 Hi, it's the RNS-D! Not BOSE. IIRC the RNS-D has the same amp setup i.e. front speakers connected direct in non-Bose. So either the internal amp is dead, or it's coded/setup for Bose which has disabled the internal amp, or the front speakers aren't connected. If the seller had it in a Bose car he wouldn't have had this problem since Bose is fully amplified. Link to comment Share on other sites More sharing options...
markos67 Posted August 25, 2009 Author Report Share Posted August 25, 2009 okee dokee, do you know where I will find the correct code for a non bose radio so I can check it with the vag com? Link to comment Share on other sites More sharing options...
PetrolDave Posted August 26, 2009 Report Share Posted August 26, 2009 okee dokee, do you know where I will find the correct code for a non bose radio so I can check it with the vag com? Try here de.openobd.org - audi - radio-/navigationssysteme Unfortunately it's in German, but the Ross-Tech wiki doesn't seem to have anything on the RNS-D. Link to comment Share on other sites More sharing options...
markos67 Posted August 27, 2009 Author Report Share Posted August 27, 2009 Thanks for that I'll give it a look over later. Link to comment Share on other sites More sharing options...
