jhal Posted August 30, 2009 Report Share Posted August 30, 2009 hi all, 06 Gti. just recently serviced, Wed. 60K Miles, plugs changed too. DSG oil change. car running fine since, went to the shops this morning. didnt drive it hard. came out of shops, started car, was about 50 feet down the road when i noticed the check engine light was on. turned around and went back to car park. turned her off for 5 mins. key out. then restarted it, light still on. opened bonnet, no unusual sounds, apart from the normal ones. put hand to exhaust, no unusual smells. drove it home, about 8 miles, all ok. did not drive it hard. it does not feel down on power, but didnt want to give it the berries in case. the book says its an exhaust issue, o2 sensor. any thoughts. the car has been mapped, but that was about 2-3 months ago. it also had its DV replaced around that time, was it was no boosting properly nothing but E5 in it.(maxol petrol) there is a local who has a vagcom, gonna pop over to him and see whats what. i presume its ok to drive on short stints. thanks. james Link to comment Share on other sites More sharing options...
petsy Posted August 30, 2009 Report Share Posted August 30, 2009 More than likely your sensor has gone bad... It's an easy fix if that's the problem. Link to comment Share on other sites More sharing options...
jhal Posted August 30, 2009 Author Report Share Posted August 30, 2009 got a local guy to do a download and clear the error anyone know how to read this stuff? Sunday,30,August,2009,17:38:05:20000 VCDS Version: Beta 907.2 Data version: 20090726 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K0 Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 VIN: removed Mileage: 94320km/58607miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 1010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 1010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 1K0 907 115 J HW: 1K0 907 115 F Component: 2.0l R4/4V TFSI 0030 Revision: --H14--- Serial number: VWZ7Z0F349 Coding: 040300031C070060 Shop #: WSC 00191 264 15243 3 Faults Found: 012599 - Intake Manifold Runner Control: Basic Setting not Completed P3137 - 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 2 Mileage: 94231 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 86.0°C Temperature: 42.0°C Absolute Pres.: 990.0 mbar Voltage: 12.192 V 001602 - Sensor Reference Voltage A: Circuit: Low P0642 - 002 - Lower Limit Exceeded - Intermittent - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 0 Fault Frequency: 2 Mileage: 94231 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 57.0°C Temperature: 51.0°C Absolute Pres.: 1000.0 mbar Voltage: 12.319 V 001089 - EVAP Emission Control Sys: Incorrect Flow P0441 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 94306 km Time Indication: 0 Date: 2000.00.00 Time: 17:10:11 Freeze Frame: RPM: 842 /min Load: 21.2 % Speed: 0.0 km/h Temperature: 88.0°C Temperature: 30.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.351 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 043 C HW: 02E 927 770 AE Component: GSG DSG 070 1111 Revision: 04507000 Serial number: 00000602111031 Coding: 0000020 Shop #: WSC 01279 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA Component: ESP FRONT MK60 0102 Revision: 00H13001 Coding: 0004738 Shop #: WSC 01279 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1K0 907 044 BD Component: ClimatronicPQ35 090 0808 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000005369640 Coding: E58D0F2700041500001400001400000000087F075C Shop #: WSC 00000 785 00200 Part No: 1K2 955 119 C Component: Wischer VW350 013 0402 Coding: 00063445 Shop #: WSC 00000 Part No: 1K0 955 559 T Component: RegenLichtSens 011 1110 Coding: 00207646 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 R HW: 1K0 909 605 R Component: 38 AIRBAG VW8 018 2200 Revision: 02018000 Serial number: 0038MD08W628 Coding: 0013112 Shop #: WSC 01269 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG Component: J0527 034 0070 Coding: 0012112 Shop #: WSC 01279 785 00200 Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1K6 920 962 D Component: KOMBIINSTRUMENT VDD 4312 Coding: 0003403 Shop #: WSC 00000 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 F HW: 1K0 907 951 Component: Gateway H10 0120 Revision: H10 Serial number: 280010621606D0 Coding: 3F0F0348070003 Shop #: WSC 00908 210 72116 2 Faults Found: 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 6 Mileage: 93932 km Time Indication: 0 Date: 2000.00.00 Time: 16:24:59 01304 - Radio 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 6 Mileage: 93932 km Time Indication: 0 Date: 2000.00.00 Time: 16:24:59 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No: 1K6 920 962 D Component: IMMO VDD 4312 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.lbl Part No SW: 1T0 035 680 A HW: 1T0 035 680 A Component: RNS-MID H04 1000 Revision: AB001001 Serial number: VWZ6Z7G7347085 Coding: 000004000000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: ------------------------- ------ 2 Faults Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 197 Reset counter: 222 Mileage: 88416 km Time Indication: 0 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 223 Mileage: 88437 km Time Indication: 0 Date: 2000.00.00 Time: 18:24:03 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl Part No: 1K0 959 701 L Component: Tuer-SG 024 2814 Coding: 0000566 Shop #: WSC 01279 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb Part No: 1K0 959 433 AJ Component: KSG 0401 Coding: 11C802087F2D8405485AC69010CC Shop #: WSC 00908 210 72116 Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Part No: 1K0 907 719 C Component: Neigungssensor 005 0003 Part No: 1K0 951 177 A Component: Innenraumueberw.005 0202 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl Part No: 1K0 959 702 L Component: Tuer-SG 024 2474 Coding: 0000566 Shop #: WSC 01279 785 00200 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.lbl Part No SW: 1T0 035 680 A HW: 1T0 035 680 A Component: RNS-MID H04 1000 Revision: AB001001 Serial number: VWZ6Z7G7347085 Coding: 000004000000000000 Shop #: WSC 00000 000 00000 ASAM Dataset: ------------------------- ------ 2 Faults Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 197 Reset counter: 222 Mileage: 88416 km Time Indication: 0 00862 - Antenna for GPS Navigation (R50/R52) 011 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 254 Reset counter: 223 Mileage: 88437 km Time Indication: 0 Date: 2000.00.00 Time: 18:24:03 End --------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
petsy Posted August 30, 2009 Report Share Posted August 30, 2009 I assume you have an after market sat nav installed for some of those errors. You can check the fault codes here, Main Page - Ross-Tech Wiki Link to comment Share on other sites More sharing options...
jhal Posted August 30, 2009 Author Report Share Posted August 30, 2009 yeah, they have been there for a while. more concerned with the engine faults. checked that ross tech site earlier. while it give an explination for the code, its not very clear. Link to comment Share on other sites More sharing options...
