Rick 63 Posted May 28, 2010 Report Share Posted May 28, 2010 Hi I have a little problem with my rear parking sensors,when I go out in the car in the morning everything ok.When I get to the railway station 30 min drive put the car in reverse,get the constant bleep although no where near anything. Exactly the same thing happens when I do the journey home,I have cleaned the sensors and soaked them with a hose pipe to make sure there clean. All ideas appreciated Rick Link to comment Share on other sites More sharing options...
Andy_Bangle Posted May 28, 2010 Report Share Posted May 28, 2010 If you get a constant bleep then that's a fault, either one or more of the sensors has failed. Last year I had two replaced and BMW one ain't cheap If you can get behind the bumper then you can check all the connectors, or if you know someone with VAG-COM then they can test them. Link to comment Share on other sites More sharing options...
