02 Audi A4 B6 OEM Se suspension and OEM Sport suspension
02audi
Hi all I'm new here
I have a 2002 Audi A4 B6 1.9tdi SE model on standard suspension(shocks need replacing).
I want to fit the Audi sport suspension, apart from replacing the shocks and springs will I need to replace anything else like swaybar drop links etc...or will I get away with just fitting the factory sport shock and spring.
I want to fit this sport suspension as I dont want to go any lower in height. I've been told that it lowers the car 15mm more than standard SE suspension and I dont want problems with negative camber (uneven tyre wear) if I go any lower.
Any info on aftermarket shock and spring kits that lowers up to 15mm info would be great
