Internet Radio
Lussac
I'm contemplating buying a Squeezebox Internet Radio but as I live abroad apparently I'll have trouble listening to BBC as it's geo-locked to UK only. I'm told if I get a UK VPN then I won't have that problem. As I know nothing about VPNs I have a couple of questions:
1) Is a VPN easy to set up?
2) Can it be set up on my Draytek 2820 router rather than my PC as I don't want to run the PC all the time the radio is on?
If you want to run a VPN, you need somewhere in the UK to connect into.
The Draytek supports VPN pass-through, meaning that any devices behind it running VPN client software will be fine. You'll probably need a hardware-based firewall if you want all (or certain) traffic to be routed to specific locations.
Your cheapest route would be to use a UK based proxy server, although you'll have to make sure the Squeezebox supports being configured to use one.
I'll try and get more details but I think there is a way of making the sender think you are in a location you aren't by simply routing your connection through somewhere else. I know my brother does this to get hold of feeds from the US and the way he described it seemed very simple.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
