swarcp Posted June 29, 2010 Report Share Posted June 29, 2010 sorry for creating a new thread but i didnt want to get bogged down in the other massive thread on this situation. ok now im about to retrofit cruise and dis and have got all the parts needed except one which im totally confused about and that is a wire listed on the ross-tech web site which says Installation & Wiring In general the whole retrofit is just plug and play except that one wire needs to be added. Wire T16a/5 from steering column control module to engine control module (see wiring diagram specific your particular car/engine). Install cruise control capable lever (see parts catalog/repair manual). can anyone give an axplanation of this required wire highlighted in red? is it the 90cm wire briefly mentioned in the long and very helpful thread? will it be there or do i need it? my car is a 2001 2.5tdi qs180, thanks in advance for any info as im ready to do the changes but on hold till i sort this out, also the vag-com coding will be done by a friend but he lives 30 miles from me, can i fit it and drive to him? i know there will be a few lights on, will it be ok or should i fit it at his. Just wanted to keep hastle for him to a minimum thats all. Link to comment Share on other sites More sharing options...
shark_90 Posted June 29, 2010 Report Share Posted June 29, 2010 You won't need the wire. You can fit it and drive to your friend but the ABS and ESP won't be working. Link to comment Share on other sites More sharing options...
swarcp Posted June 29, 2010 Author Report Share Posted June 29, 2010 as always shark your the man, il be popping in next time im near for a key to be coded, will pm you nearer the time Link to comment Share on other sites More sharing options...
shark_90 Posted June 29, 2010 Report Share Posted June 29, 2010 No problem, see you then Link to comment Share on other sites More sharing options...
