faulty phone module on second hand A8?
checkleylane
hi, looking at a second hand A8 on 53 plate, but one problem, apparently the MMI comes on for a few seconds then stops working so no sound or other stuff available. Seller stated over the phone that it was a faulty phone module that was causing this to occur. not sure if this is b*s or the truth, said it was a common fault on the cars? Not seen the vehicle as it is a good journey but just wanted to check out if this is a poss or is it going to be expensive to repair. No point buying an A8 with out all the toys!! thanks to anyone with a helpful comment or info i can check if i look at the car to help maybe see if this is the actual fault? all the best.
If it's the phone module, then it's a couple of hundred to replace and you're as well upgrading to bluetooth while you're at it for the same price (car will likely have the old-style handset unit).
Where is the car? Might be someone nearby who could scan it for you for faults and tell you exactly what's wrong.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
