Screeching noise
Muppetboy
The last couple of days I've been getting a screeching noise from the front driver's side wheel... initially it was only when I braked but now I've started hearing it while I'm not on the brakes, although it's much quieter.
So initially I thought it was the brake pads but now I'm not sure... any ideas?
Not got that much time at the moment to get it looked at but obviously don't want to to drive it if it's something serious...
Couple of things spring to mind.... very very occasionally you can get a very small stone / grit caught between the brake pad and disc, the resulting noise makes you think you have worn right through the pads to the bare caliper.
The other alternative might be that you HAVE worn right through the pad.......
Guest
Reply to this topic...
  Only 75 emoji are allowed.
