whisky777 Posted October 5, 2010 Report Share Posted October 5, 2010 Hi i have a v5 passat estate it has a misfire.Changed coil pack (multiple coil pack agz engine)still misfire.Changed ignition modual lost misfire but now cuts out after a couple of minutes,restarts straight away then cuts out again and again and again.So put old modual back on no cut outs but back to misfire on same cylinder.Whats next? Do you think new modual might be faulty?No error codes showing. Quote Link to comment Share on other sites More sharing options...
cruiser647 Posted October 10, 2010 Report Share Posted October 10, 2010 Hi, welcome to TSN Did you change all the coil packs at once? Or just one? How about changing the plugs too? Also, when does it mis-fire? During acceleration, on the run off, during idle? Quote Link to comment Share on other sites More sharing options...
