gaz87 Posted December 19, 2010 Report Share Posted December 19, 2010 wot dose a purge flow sensor high do this is 1 ov the fault codes that came up plz HELP Link to comment Share on other sites More sharing options...
cruiser647 Posted December 20, 2010 Report Share Posted December 20, 2010 wot dose a purge flow sensor high do this is 1 ov the fault codes that came up plz HELP Hi, and welcome to TSN. Can you tell us again what the error and the symptoms are please. In English? Thanks! Link to comment Share on other sites More sharing options...
gaz87 Posted December 20, 2010 Author Report Share Posted December 20, 2010 (edited) hi thanks for your reply the car was workin fine till a few days ago i was driving along an then the car started puffin white smoke an then it just died an then i put a code reader on it an it fetch up these codes 1 on the fule pump sensor open circuit an peurge flow sensor high . the car dose not start on its own fuel it only starts wen i used easy start it only run for a few seconds hope you can help thanks Edited December 20, 2010 by gaz87 Link to comment Share on other sites More sharing options...
burble Posted December 20, 2010 Report Share Posted December 20, 2010 I think I can just about translate that into English: Hi, thanks for your reply.The car was working fine until a few days ago. I was driving along and then the car started puffing white smoke and then it died. I put a code reader on it and it registered a fault with the fuel pump sensor "open circuit and purge flow sensor high." The car does not start on it's own, it'll only start when I used "easy start" and even then it will only run for a few seconds. I hope you can help. Thanks. Link to comment Share on other sites More sharing options...
TIDYDUBS Posted December 21, 2010 Report Share Posted December 21, 2010 What work has been done???????? Model?...engine? Link to comment Share on other sites More sharing options...
