Stoobee Posted August 4, 2011 Report Share Posted August 4, 2011 I have a Saab 93 'vert' on a 06 plate. My question is this......is there any way I can play mp3s through the current music system ?Without having to rely on 'through a radio channel' scenario, which more often than not doesn't work and when it does it gives poor results. Link to comment Share on other sites More sharing options...
Scotty Posted August 4, 2011 Report Share Posted August 4, 2011 Over the years there's been various solutions. I've used a couple in the past : [1] A device the plugs in line with the aerial and that inserts the analogue feed in via a radio frequency. You then just use a radio preset. [2] A device that transmits on a frequency that you tune in to [3] The cassette adaptor device - it leaves a cable hanging out which you connect to your player I'm assumming being an '06 car that it doesn't have a cassette adaptor. Another thing I did on my B6 S4 was to feed music/satnav instructions into my headunit via connections on the rear of the unit. I did this as the car could be bought with factory satnav and this would connect to the head unit via 3 micro spade connectors. It did need a little box in between so I could set the trigger levels for it to cut in (i.e. lower the music and play the nav instructions and then raise the music again). You obviously need away of getting the signal into the head unit. Your options depend on what's available. Link to comment Share on other sites More sharing options...
NewNiceMrMe Posted August 4, 2011 Report Share Posted August 4, 2011 The only really decent solution is to have an MP3 adaptor fitted. The likes of Autosounds would be able to tell you if one was available for the Saab and how much it'd cost - but I think they average around £200. Link to comment Share on other sites More sharing options...
eldavo69 Posted August 4, 2011 Report Share Posted August 4, 2011 I have a Venturi mini for Bluetooth and music (supports A2DP) that plays through a radio preset and it works very well. Link to comment Share on other sites More sharing options...
