Greggster Posted January 11, 2012 Report Share Posted January 11, 2012 Hi everyone - bought my first audi in november last year. Was loving every thing about it until my emission control system warning light came on. Figured in the long run it would be best to be able to read the faults myself so bought a vagcom cable and extracted the codes. I've got the following error appearing 5294 - Throttle Valve Actuator Module (J338): Motor Circuit P2103 00 [032] - Signal High Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Any steer as to how serious this is or what to do? The motor's an 2008 A4, B8 model 143 2.0 Diesel. Thanks gang Quote Link to comment Share on other sites More sharing options...
richlean Posted March 25, 2012 Report Share Posted March 25, 2012 What happened next, Greggster? The same fault appeared on my 2008 B8 2.0TDi 143 today. My OBDII app shows the throttle position to be around 87% even when I'm at idle, so I suspect a faulty sensor somewhere. The car drives fine, though. Quote Link to comment Share on other sites More sharing options...
