craig1712 Posted February 24, 2012 Report Share Posted February 24, 2012 I hope someone can help. I have an Audi A6 2003. I have replaced the factory Symphony II with a 4B0 035 192 P. I have hooked it all up and it works great for MP3’s Radio ect but the sat nav is not moving. It will occasionally update the location but almost once every 5 mins. I am showing between 5 and 7 Satellites. I have not coded it to the car yet, but the Lights dip on the RNS-E with the head lights and it turns on and off with Ignition, it is getting Date and Time from the Car and displaying Music info in the DIS. I have not connected the Pulse cable as I was under the impression that it is not required unless you want Gala. Do I need the Pulse or do I have another issue here? Link to comment Share on other sites More sharing options...
Tipex Posted February 24, 2012 Report Share Posted February 24, 2012 Assuming the Audi system is the same as all the other VAG systems of the period, it will need the pulse as well as the satellite. On the VW sat nav it had two separate connections for the pulse, one for Gala, and one for navigation. Link to comment Share on other sites More sharing options...
craig1712 Posted February 24, 2012 Author Report Share Posted February 24, 2012 Ok Thanks. Do you know which pin on the RNS-E is the Pulse link. Thanks Link to comment Share on other sites More sharing options...
Tipex Posted February 24, 2012 Report Share Posted February 24, 2012 Sorry I don't, I'm sure someone who does will be along shortly though. Link to comment Share on other sites More sharing options...
craig1712 Posted February 24, 2012 Author Report Share Posted February 24, 2012 Think i have found my answer here http://home.comcast.net/~nelson.paiva/RNS-E.pdf Think my anwser is step 25 and 26 can anyone confirm?? Thanks Link to comment Share on other sites More sharing options...
craigyb Posted February 24, 2012 Report Share Posted February 24, 2012 Yep, A6 requires a speed pulse and steps 25/26 cover it. Link to comment Share on other sites More sharing options...
craig1712 Posted February 24, 2012 Author Report Share Posted February 24, 2012 Thanks! I will have a go this weekend. Link to comment Share on other sites More sharing options...
megancheung Posted April 11, 2012 Report Share Posted April 11, 2012 it doesn't matter which mode you on. your unit should automatic update. did you let it load for a while? Link to comment Share on other sites More sharing options...
Basketcase Posted August 15, 2012 Report Share Posted August 15, 2012 Hi, I've just changed my Symphony II to the RNSE sat nav unit and have the same problem that you mentioned with the position not updating on the on the screen. Hope you don't mind me asking, did steps 25-26 resolve it. Many thanks. Link to comment Share on other sites More sharing options...
