ryno Posted March 10, 2012 Report Share Posted March 10, 2012 [TABLE=width: 100%, align: center] [TR] [TD]Hi, i'm new here and this is my first post I have an A4 B7 Cab which has only done 38k but is over 5 years now and apparently due for it's cam belt change. I bought the car a year ago with full main stealer service history and have since had an 'interim' service which was £149 at the local stealer, they didn't throw any extra costs in so all good. I just called them to ask for a quote for the cam belt and they say it's £429, but recommend getting the pulleys, tensioners and water pump done at the same time (which would bring the cost to £724) • Cam belt change £429 • Water Pump £135 • £160 Pulleys and Tensioners What are your thoughts on this? I want to get the cam belt done at the stealers for the stamp on such a major job, but they reckon it's a lot easier to do the pump and tensioners at the same time while they're doing the belt. Should i just get the cam belt done for now and look for a good non-steeler garage to get the other jobs done? Cheers! [/TD] [/TR] [/TABLE] Link to comment Share on other sites More sharing options...
chody Posted March 11, 2012 Report Share Posted March 11, 2012 use oem parts but get it down to an indy mate, i got the parts for my vw for 200 and luckily my mate did the work and stamped the book with his garages stamp , i dont think you need a dealer stamp for this work but if you have the receipt to show you used oe parts that will satisfy most buyers. Link to comment Share on other sites More sharing options...
megancheung Posted April 11, 2012 Report Share Posted April 11, 2012 This is the most complete kit I have seen. When is the timing belt service scheduled for the 2.0T? Link to comment Share on other sites More sharing options...
