SeanJ Posted June 7, 2012 Report Share Posted June 7, 2012 Hi all, I'm new here but have always found the advice given to others helpful so I wonder if someone could advise on my problem please. Last year I chaged the LUK/Tamdem pump on my A4 B6 - it was one of the ones that started to leak. The part I fitted was used but worked fine. I recently developed a brake problem which initially indicated the servo may have failed - common on 02/03 B6's I understand. On closer inspection my mechanic now thinks it's the pump again as the vacuum inlet nozzle ( servo to pump connection) on the pump moves in it's housing - he said they should be tight like the other ( fuel) side and is probably letting air pressure drop. Now the thing is I have just checked the old pump which I still have and the nozzle on that also moves - the brakes were fine with this pump it was only a fuel leak that forced the replacement. Can anyone clarify please? I really don't want ( and can't afford) to lay out £300 on a new pump only to find that's not the problem and I then have to buy a brake servo as well. My guy is an Audi Specialist and has looked after my car since new so I trust his opinion, but it's odd that both pumps have the same revolving nozzle surely? I would really appreciate any knowledge/advice. Thanks Guys Sean Link to comment Share on other sites More sharing options...
