broken springs on boot latch replacement wont lock ,shut ok passat saloon
rush2112
I think I have the same problem but I cant get in the boot !! do you have any advice ......please
hi you will have to get in to the boot from the back seats and remove the boot trim then release the lock manually make sure that you remove the torx screws holding on the trim they are in the hand holes then pull it off
finally remove the latch when open and replace it with a new one
Guest
Reply to this topic...
  Only 75 emoji are allowed.
