A3 2.0tdi ENGINE MANAGEMENT LIGHT, PLEASE HELP
happychap
hi there, hoping you can help me, I have a 2005 2l tdi, a couple of days ago the engine management light came on the dash, car was running fine, light came on and the throttle response is slower, and the engine is running "rough"
had it scanned by ATS and got 2 reports from them:
EODB reported fault codes
P2100 throttle valve control motor open circuit
P2102 throttle valve control motor signal too small
Bosch system reported Engine Management System 1 fault codes
463 throttle valve communication faulty
500 cooler fan stage 1 short to earth
459 throttle valve short to earth
circulating coolan pump voltage too high (sorry no number for this one)
cleared the faults, restarted car, light stayed off for a few minutes, then re-appeared, rescanned and same fault codes came up, cleared once more, started engine, as i drove off, light came back on
I am wondering if this is likely to be a wiring issue (not sure if the 2 circuits are routed through same connector maybe??)
or maybe a sensor fault
or maybe worst case scenario of a new throttle body?
Any advice would be welcomed, I would prefer not to have to rely on main dealer if possible, but even some idea of what costs might be involved would help a lot
I am in the Accrington area, if anyone knows of an independant specialist in the area this would also be a massive help
thanks in advance
