Stuck plug - HELP!
IceBlue8
After a service, my independent Audi specialist advised that one of the plugs is stuck (number 5). Apparently it's not seized, as it moves a little, but they reckon it's cross threaded and the swarf in the threads is preventing removal.
They recommend taking the head off and sending it to an engineering shop, which will cost a shed load and take up to 2 weeks!
Is there an easier way?
A similar situation happened to one of the guys at work. Fortunately we were able to work it loose with brute force which did result in us totally destroying the thread in the head. Was then just a case of drilling oversize and tapping for a helicoil into which we then screwed the new plug (after hoovering the cylinder using some 6mm ID pipe attached to the Hoover with good old gaffer tape).
Was as good as new for about six months until the rust finally got the better of the car
Think the big difference for you might be that this was on a 13year old 406 diesel and it wasn't mine :) but in theory it should be possible. If it doesn't work you'll have to take the head off so you haven't lost anything by trying.
Diesels don't have spark plugs, but the principle is the same. +++
I've had similar. Unfortunately the thread had damaged, so even after the plug was forced out, it was a head off and then drilled out and a helicoil put in.
Mine was an old Porsche, which is an engine drop, cam / carrier removal, head removal and rebuild. Not cheap.
Yours could be a lot simpler with the head coming off relatively simply with engine in situ.
