BRM Posted November 2, 2012 Report Share Posted November 2, 2012 Help required - I've had this Audi a few months and after bying it found it to have a warm/hot start issue. The engine turns over quickly though fails to start. When it's cold there is no problem starting at all. The car has been to an Audi garage who say there is no problem (convenient for them). It did go to a smaller garage and they have also been unable to find a fault. The cam sensor has been changed and a new battery fitted with the winter approaching and not wanting to be stranded when the car has been stopped for a short time while popping into the shops or filling up ! I can not see anything obvious and have been searching the net for a similar problem that someone else may have regarding the above. I have seen starting issues on petrol models though these do not answer the issue as mine is deisel. Your thoughts, help and solution would be most useful as i'm sure you all know what Audi garages charge who themselves said it was the starter motor that need replacing at a cost of £800+ I have at this moment lost my faith and trust in the local main dealer !! Thanks BRM Link to comment Share on other sites More sharing options...
