Hopsta Posted January 21, 2013 Report Share Posted January 21, 2013 I've been looking at an old SBS 2003 box and trying to work out why the disk to disk performance is poor. i.e copying a 61Gb file from 1 partition (Raid 5) to another takes 2 hours and the raid controller shows it should be at a rate of 320 MB/s. Which should be roughly 3½ minutes, unless my calculations are fubar'd!? The box is far from state of the art - Quad Core Xeon - x86 / 2Gb RAM which is normally max'd out, so I'm guessing that disk paging will be affecting performance but not a massive about. The server runs about 20 Exchange Mailboxes / AD etc etc (standard SBS setup). I've tried increasing Page file sizes but that not made much of a difference, would the RAID Stripe size make cause poor performance? its set at 256Kb which I assume is the out of the box setting. Perfmon isn't showing any real queue issues.... Any ideas? Quote Link to comment Share on other sites More sharing options...
Mac Posted January 21, 2013 Report Share Posted January 21, 2013 What makes you think write speeds will raw out at that capacity? RAID 5 includes parity calcs, and that can kill your write speeds. Have a look in your PerfMon and I bet your disk queues are big, yes? Quote Link to comment Share on other sites More sharing options...
Hopsta Posted January 21, 2013 Author Report Share Posted January 21, 2013 I no doubt I'll not get the 320MB/s as you say, but the gap between that and what we are getting is vast. I'm in the process of chopping folders about but will run a bench test as it's been a year since I ran this. A colleague said they checked perfmon and this was at an average of 1 for disk queue, but will double check later on. Quote Link to comment Share on other sites More sharing options...
Mac Posted January 21, 2013 Report Share Posted January 21, 2013 That would point to a hw issue then wouldn't it? If the sw queues are working? Quote Link to comment Share on other sites More sharing options...
