Best (cheapest) Place to get runflat tyres?
Waylander
  • 4 weeks later...
Have you tried your local place? I've always found, without exception, them to be much cheaper than any online supplier once you factor in fitting the tyre plus balancing, valves etc.
In this case the local place was cheaper its own online quote even!
Decided I would give the Hankooks a whirl. I was shocked how badly the driver side front has deteriorated so needed at least a couple PDQ.
Cheapest = Camskill at £142 each plus delivery. (~£290 all in)
Place I used to use charging £162 fitted
Rang them and they said they have to order them in and will do me 2 for £304 fitted +++
Out of interest, do you ever hear a clunk from the rear wheel area?
I ask because that model is known for springs going bang in the same way the E46 M3's were.  The 5 series range of that era had the issue too.  They're cheap to replace and make a massive difference.  That could very well impact tyre wear (it certainly hits the ride).
Hmm.  Put the windows down and drive slowly, very slowly, over a speed bump or ramp.  It'll be a short clunk if it is a spring.
It took me ages to realise it on mine.  You do see a slight change in the stance of the car but you have to look very, very closely on flat ground.
Wheel/tyre balancing makes the judder, tracking/alignment wont, but i'd be surprised if poor alignment took out both tyres on one side.
It is possible of course, but would tend to indicate a more serious underlying problem, such as previous accident damage.
It could simply be because a previous owner had a series of punctures, and didn't replace tyres on the same axle at the same time, and i'd suggest this is the most likely explanation.
Are the front/rears swappable? Some BMW's have different sizes front to rear.
