Camber, tracking, wheel alignment on A4 Cab?
Keegs
Anyone had any problems? Just come back from a week in the Lakes and noticed that my two rear tyres are worn on the outside but ok in the middle and inside. Tyre pressures were checked before and after and everything was ok, never had an accident and hit any majore pot holes. Spoke to the dealer and they want to charge £306 for an alignment check to start, is this right? Has anyone ahd a similar problem??
Had exactly the same on my previous Cab. Unusually the tracking is adjustable on the rear of the A4. My car was about 15 months and 13K miles old when I first noticed. The dealer did the check and corrected the alignment under warranty. I attempted to get some compensation for the reduced tyre life. No dice - apparently Audi won't guarantee wheel alignment for more than 3k miles, due to it being so easy to knock out confused.gif (should build them tougher then IMO).
Hope you manage to get them to phut the bill as well.
Seemed really wrong to me that a FWD car was going to wear out its rear tyres before the fronts.
Cheers
CM
Thx for that CabMac. Dealer wouldn't budge and customer service said take it up with the dealer! So I went to a local performance tyre place and all they could find was the front was way out. They think that maybe these were the tyres on the front and they were swapped over during the recent service as the rear alignment was spot on... now had the tyres replaced and see how they go... here's a picture of the offending journey, obviously not cab weather but it did well over the passes in the Lakes!
