eenlt Posted August 26, 2004 Report Share Posted August 26, 2004 Does anyone know where I can get a cheap PCMII (sat nav)? Dealer price is £3,150 plus £1,500 for the tel module. I have tried a few dismantlers and ebay but no luck so far. Link to comment Share on other sites More sharing options...
shao_khan Posted August 26, 2004 Report Share Posted August 26, 2004 Welcoem to Tyresmoke. can you get them direct from the manufaturer? Could be Becker, might be cheaper than porsche. Link to comment Share on other sites More sharing options...
Cantankerous Posted April 27, 2009 Report Share Posted April 27, 2009 Hi After a flat battery / Sunday morning alarm incident I've got a problem with the PCM / BOSE audio system in my 53 Boxster. The speakers 'pop' every 10 seconds or so before the key is in the ignition and the PCM unit only turns on intermittently. There is also a constant drain across the battery which disappears when I pull the fuses for the audio / sat nav. I've got three questions for you: 1) Firstly, any ideas on what the problem may be and any suggestions as to how to fix it (other than going to the dealer for a new unit)? 2) If I have to replace the PCM, anyone know where these can be purchased second hand? 3) Do you know of any aftermarket replacements for the PCM unit? rgds/alex Link to comment Share on other sites More sharing options...
richy_uk Posted April 28, 2009 Report Share Posted April 28, 2009 Only place I've seen PCM I and II come up regulalrly is the German eBay site. I think there is a supplier in the US that sells them cheap, but since the exchange rate shifted, they became less appealing. Link to comment Share on other sites More sharing options...
