Wireless setup.... nearly
Hants_Cruiser_UK
Well I have finally got my Belkin all in one ADSL/Router/Wireless set up and its working a treat..... eventually tongue.gif
What should have been a 10 minute job turned into nearly 4 hours - lots of scratching of head and calls to Wanadoo highlighted the fact that I had been entering the wrong password for my connection and had frozen out my account smashfreakB.gifsmashfreakB.gif
Tested the Firewall on "Shields UP" and Symantec's online "Security Check" and all came back fully stealth etc... The only setting I have so far had to add to the builtin firewall is for IUCII. It has some preset applications that it thinks I may need, except the trigger port it used by default was 2019. This didn't seem to work, so after looking at my ICUII settings I realised it needed to be 2000 and heypresto it works smile.gif
When I ran "Shields UP" again all was fine, but running the Symantec check it said I was vulnerable to Trojan Horse attack UHOH7.GIF Which one do I believe. As soon as I come out from ICUII that risk does not show..... so it would seem according to them I am at risk when using ICUII??
PS it has an idle time setting which drops the ADSL connection after a set period, but after it does that it doesn't seem to autoconnect, so I have now set it to zero so it stays connected???
PPS The wireless part is diabled at the moment until I get XP loaded on my new laptop (Birthday pressie to myself) smile.gif
but then again, ive not needed to mess about with my ports and access anyway.
as for redialing, if you let it time out, you need to tick the check box "dial on demand"
its under internet WAN -> connection settings-> next -> and its on page 2 hust above the idle time box.
even tho i have my idle set at 0 i still have got this box checked, incase it drops off. Saves going into configuration to start it up.
I guess I will have to see how things go about opening the port confused.gif
I am going to try the idle disconnect at 5 mins again, just to see if it works now I have done some tweaking crazy.gif
Internet does seem that little bit more responsive now I am not using the USB modem smile.gif
HC
There is also a new firmware out before you get too settled.
I saved my old set up, applied it, and it wiped everything.
my saved configuration , didnt reinstall as it said it was "too short" confused.gifsmashfreakB.gifconfused.gif
so ive had to start from scratch with the settings.
still, whilst you can remember what your doing, it might pay to update it.
(if yours hasnt got it already from factory)
Linky.
Thanks for that Paul, but I have just been on the phone to Belkin Technical and it looks like I have a faulty unit.
I have been having troubles getting my laptop to connect, and it seems that the WLAN light should be lit all the time regardless as to a connection being present, but mine isnt lit and therefore the laptop cant see it frown.gif
Is yours like that? We did a factory reset and held the reset in at the back for 2 mins and still no joy.
I struggled with this...
infact ive fecked mine up trying to ugrade my laptop to XP SP2 fekr.gif so im fiddling with mine as we speak..
Right wireless...
IIRC i had to turn mine on. to get the 4th Green light ON.
and like Belkin say, it should be on all the time, regardless of if its working.. (it blinks when communicating IIRC)
to turn it on..
log into set up page.
and click WIRELESS heading in blue.
Its got a simple enable/disable option on it.
After all this talk of wireless, my Draytek Vigor 2600 seems to have given up the ghost, nearly!
Wireless works fine for about an hour, then just "stops". I have two wireless machines and they just can't see the router any more. If I do a software reset of the router (from a wired PC) then wireless starts working again, for about an hour. It only stops after an hour of use though... if there is no activity for a day or so it's fine, until I switch the laptop on and start using it. I've upgraded to the latest firmware, and even tried the new beta release, but no difference.
Anybody got any ideas - or should I just bin it and buy something else. If so - can anyone recommend a good combined ADSL router, with 54M wireless, decent aerials (twin external atleast), and atleast 1 wired ethernet socket?
Right wireless...
to turn it on..
I have done that I have noticed that when you enable it and apply the settings the lights appears briefly and then goes out confused.gif.
i had similar problems and found it was down to certain batch of microsoft updates messing mine up.
Turned them off on Laptop and all was perfect.
Now im fiddling again and trying SP2 and its doing all sorts of weird things.
excellent signal, but wont let me connect to the net at all
i will not give up.......................
If it's just the wireless which isn't working, and you're happy, otherwise, with the Vigor, why not just buy a separate wireless access point.
I have the Vigor 2600X (no wireless), and use a separate 3Com 802.11g WAP.
yes, i seem to up and running again, i just tried updating too much at the the same time.
my wiresless has a rock steady light at the mo, and its not in use.
Out of interest who is your ISP?
I am with Freeserve/Wanadoo and with all the fiddling around I have done, it seems to work whether I use PPPOE or PPPOA. Just wondered which one it should be?
PS is there any problem with having it connected to the ADSL line all the time, only auto re-connect never seems to work confused.gif
how quick is it?
well 802.11b (11Mb) is 22 times faster than 512Kb broadband...
so even when you have a crap signal far away from the router
through ceilings and walls etc, it is always still more than enough for 0.5 - 2mb broadband and beyond.
later spec 802.11g is even faster at 54Mb.
so broadband over wireless is never going to be an issue.
I have a 802.11g (54Mb) capable router, but choose to use the built in laptops 802.11b (11Mb) wireless so i do not need a lump sticking out the side of my laptop.
Sorry HC , only just seen this.....
<font color="blue"> Out of interest who is your ISP? </font>
Pipex www.pipex.net
<font color="blue"> I am with Freeserve/Wanadoo and with all the fiddling around I have done, it seems to work whether I use PPPOE or PPPOA. Just wondered which one it should be? </font>
Mine is PPPOA
<font color="blue"> Also do you use LLC or the other one MMC I think </font>
Its LLC or VC MUX ..... mine is VC MUX
I got these settings off my ISP's website, under advance user setup, for aftermarket kit like routers etc...
im sure wanadoo do do do similar grin.gif or offer settings via technical support line..
<font color="blue"> I am hoping to pick up my new unit later today </font>
good luck. They are a good bit of kit, and can be left alone once working. 169144-ok.gif
<font color="blue"> PS is there any problem with having it connected to the ADSL line all the time, only auto re-connect never seems to work </font>
None at all.They are designed to be always on. Mine is on 24/7 although PC's are turned off when not in use.
The only problem I have found with my laptop is I take it from my house to my g/f's house. Both locations use Netgear Routers/Gateways. I have problems with obtaining IP address when swapping between locations, this is usually fixed by a router reboot or laptop reboot.
Pipex www.pipex.net
Mine is PPPOA
Many thanks Paul.
I have just check Wanadoo and found this:
Advanced settings
These setting are only required if you use a computer running a non-Windows operating system, or you are setting up a Router to share your Internet connection.
IP address
Your IP address is allocated dynamically via DHCP- you do not need to set this. We are unable to offer a static IP address.
DNS
Domain name service is dynamic - but if domain name server (DNS) addresses are required, you should use 195.92.195.94 and 195.92.195.95
Router settings
If you choose to use an Ethernet modem / router, the correct connection settings are:
Encapsulation:
PPP over ATM
Multiplexing Method:
VC-Based
Virtual Circuit:
VPI=0
VCI=38
I am sure I looked before and couldn't find it, so hopefully now I have the correct stttings. I am pretty sure that is what I was using before, but at least this time I know for sure smile.gif
Paul
The only thing I am a bit confused about is that in the intel profile it gives the MAC address of the access point a different number to what I think it should be. I am connected to my network, but am just a bit puzzled. confused.gif
Also I was surprised that my network showed up when I did a scan of the networks mine was visable,but maybe because the laptop was on the MAC address list
each item you allow to connect will have its own MAC address.
i have two addresses...
Desktop PC
Laptop PC and thats it.
If you have turned off your ESSID as belkin call it, it stops Shouting "belkin54g" or whatever you have called it....
so only if you have the right Mac Address, and already know the ESSID name should you get in. THEN you need the right encription WEP, WPA whatever you have set...
there are programs out there that will show youe ESSID. Even if hidden. But if hidden
Your neighbour cant easily see it ..... It certainly should not pop up "HC's Wireless Network Here " message when they fire their laptop up, unless they get another (often free) bit of software to sniff it out.
Then they still would have to crack it, if you have secured it right.
Thats how i understand it.... you can see it, because you have set it up to allow you to see it..
so do you need a ADSL Router and then Wireless gadgetry!?
HC and i have a Belkin ADSL modem, Router and Wireless box all in one
then either built in wireless in laptop or a card like my one in the marketplace..
an all in one box like mine and a wireless card can be had for sub £100.
Desktop PC
I have the same and just have the desktop PC and the Laptop in the MAC address list of allowed computer to be able to connect:)
I thought that MAC addresses never changed and were kind of like hardware fingerprints?
I feel a bit happier about the SSID now. I have changed that from Belkin 54g to my own. At the moment I am using 128 WEP, but I believe WPA is more secure. What are you using?
