A4 Driver's side mirror - need help!
ms363
First, see if the adjuster motor is properly fixed, and the glass to the motor. See instructions here (scroll down).
Also, IIRC, there is a procedure in the owners manual to readjust the mirrors manually if they are 'out of line'. From the top of my head (please check the manual!) you need to manually push the mirror glass gently to the smallest angle (i.e. towards the window). Then readjust with the electric adjuster.
Maybe that helps. If not, it may be required to replace the motor.
HTH
