How do I remove my gearknob?
AudiPartner
what you need to do, sir, is the following:
unclip the leather gaitor from the console. i did this by just pulling it.
pull the leather gaitor all the way up. you'll then see a metal clip at the bottom of the gearknob. unclip it and pull the knob off. Tis as easy as that.
to remove the gaitor, you'll have to remove the plastic sleeve inside the leather gaitor. just unclips.
I tried installing the TT gearknob on mine the other day but it's a different design completely which is a bummer.
you might have a problem reinstalling the metal clip. i just used a cable tie for mine and it worked fine.
Hope this helps!
Floyd
