In built microphone location
craigyb
I'm just hacking my S8 to pieces to get a Parrot Bluetooth car kit installed. Does anyone know the location of the in built microphone. I want to sap it for the parrot supplied one as the signal is very weak. Other than that I've nearly completed the bluetooth conversion using the existing wire loom for the phone prepration.
Whoopee, all sorted now, I have Parrot bluetooth kit utilizing the existing wiring for the cullman adaptor. It's about a 20 pin connector with mic.speaker, +battery, ignition, gnd etc under the center console. The parrot kit is exactly the same size as the cullman so it just slotted into the same housing. Audi's microphone is quite complex so I just swapped it out for the parrot supplied one.
Craig
