[Audi A3/S3] Ram air intake
gaia
Hello Paul
Thanks for your opinion.
As I mentioned, it gets hot in South Africa. These cars don't perform well when heat sinks in. I guess it could be considered extreme, but I am a fanatic and I love to tinker, rather than bolt on.
Another attachment showing the turbo-fan herewith.
Regards
Stuart
Hello Drillslinger
Thanks for your input. Out of interest, which ideas might you try on yours mate?
I like how you've gotten the feed from the "Wheel Well" to the front. I always thought the facelift air feed went all the way through the wheel well, but when I dropped my front end to swap grills, found out that all it did was pull air from the engine bay smashfreakB.gif But the way the metal is, it's a PITA to get any hose through. So I like the way you've modded it up to make room 169144-ok.gif
Hello Drill....
Yep, I guess if you are going to do it, do it right, but admittedly this was a big job and the car was out of action for a while, which is inconvenient and a pain. So nice to drive her again though.
More detail attached.
Regards
Stuart
I understand dude. The job done on your car's Ace though 169144-ok.gif But it shows me that there ARE possibilities wink.gif I figure I'll just do something with a 90 degree bit of PVC. Question though, how much of a "Structural" piece is the metal bit in front of and below the std air feed? Think if I just cut a "U" shape into the front to allow some air hose to drop down it'd be OK?
Didn't mean the wing Paul. What I was reffering to was the shiny silver bit shown here:
After the hose comes through the "wall" it drops down over a "Shelf" of Alu, then drops down towards the front. On mine, that "Shelf" comes forward too much to squeeze the hose through smashfreakB.gif
yes i follow, i meant to get the duct up past the headlight.
Thats alot of work.
Hello Guys
Drill, I don't think opening up the standard feed hole will compromise the structural integrity of the plate, especially if you reinforce the connection of the pipe tunneling through, as I have done. In itself, a round pipe has tremendous structural strength.
