r32brkwi Posted December 26, 2004 Report Share Posted December 26, 2004 I've posted up in the 'tex, here is the link to Audi convenience in the R32 Interior light mods Vortex post Link to comment Share on other sites More sharing options...
Riz Posted December 26, 2004 Report Share Posted December 26, 2004 Nice.... just a quick question, was it difficult to fit the 12v power outlet in your boot? Riz Link to comment Share on other sites More sharing options...
mattcony Posted December 26, 2004 Report Share Posted December 26, 2004 There really easy to do Riz as the plug at the back is already there ! If you remove the little access flap you will see the plug taped up to the main loom with masking tape. Very much like the footwell lamps and an extra in the boot would be good also as the 1 at the bottom is useless. cheers matt Link to comment Share on other sites More sharing options...
Riz Posted December 26, 2004 Report Share Posted December 26, 2004 [ QUOTE ] There really easy to do Riz as the plug at the back is already there ! If you remove the little access flap you will see the plug taped up to the main loom with masking tape. Very much like the footwell lamps and an extra in the boot would be good also as the 1 at the bottom is useless. cheers matt [/ QUOTE ] Wicked so does that mean if i had a sub i could wire it off there? Riz Link to comment Share on other sites More sharing options...
mattcony Posted December 26, 2004 Report Share Posted December 26, 2004 I beleave some people have done this yes, more on the MkIV forum I think. It won't take too much current but should be enough to power a small amp. The only problem you may face with an amp powered from there is interferance. The Mk4 suffers quite badly with noise esp from the ECU's and HID's ect, going direct to the battery is the key. Some people seem to get away with it fine though, when I did all my ICE i did suffer badly with wine noises and buzz. cheers matt Link to comment Share on other sites More sharing options...
Riz Posted December 26, 2004 Report Share Posted December 26, 2004 [ QUOTE ] I beleave some people have done this yes, more on the MkIV forum I think. It won't take too much current but should be enough to power a small amp. The only problem you may face with an amp powered from there is interferance. The Mk4 suffers quite badly with noise esp from the ECU's and HID's ect, going direct to the battery is the key. Some people seem to get away with it fine though, when I did all my ICE i did suffer badly with wine noises and buzz. cheers matt [/ QUOTE ] Mmmm cool.... i will keep it in mind. Riz Link to comment Share on other sites More sharing options...
r32brkwi Posted December 26, 2004 Author Report Share Posted December 26, 2004 [ QUOTE ] Nice.... just a quick question, was it difficult to fit the 12v power outlet in your boot? Riz [/ QUOTE ] Hi Riz, mine came that way, and i personally do not recommend to connect a Amp to this powersource unless you want to add 20Watt to your system and let . Link to comment Share on other sites More sharing options...
r32brkwi Posted December 26, 2004 Author Report Share Posted December 26, 2004 [ QUOTE ] Very much like the footwell lamps and an extra in the boot would be good also as the 1 at the bottom is useless. cheers matt [/ QUOTE ] Hi Matt, the useless light at the bottom of the trunk, drove me nuts and into adding lights, turned me into a light Franz Link to comment Share on other sites More sharing options...
Riz Posted December 26, 2004 Report Share Posted December 26, 2004 [ QUOTE ] [ QUOTE ] Nice.... just a quick question, was it difficult to fit the 12v power outlet in your boot? Riz [/ QUOTE ] Hi Riz, mine came that way, and i personally do not recommend to connect a Amp to this powersource unless you want to add 20Watt to your system and let . [/ QUOTE ] Mmm yet another thing standard on the US R32`s I dont really understand car electronics but i assumed that 12volts was ok for a amp? how much does the car battery output? Riz Link to comment Share on other sites More sharing options...
r32brkwi Posted December 26, 2004 Author Report Share Posted December 26, 2004 Quote RIZ I dont really understand car electronics but i assumed that 12volts was ok for a amp? how much does the car battery output? Riz 12 Volt is the on-Board Voltage, the outlet is limited with the maximum current it allows without dropping in voltage. The Amperes make it. The outlet is hooked up to a 0.75mm2 wire, leaves you with P=U*I as its basics to wattage. recommendation is for the 0.75mm2 wire a max current of 8 Ampere @ a temperature of absolute 0 since we live in 20-22DegreeC enviroment gives the copper a resistance there for it acts like a heater. i am coming inot details here...sorry P=U*I 12Volt*8Ampere=96Watt connection max. in my opinion not much of an Amplifier if you calculate with a coefficiency of 0.7 leaves you with 67Watt Power to the Speakers. Way too long of a post. I am going Link to comment Share on other sites More sharing options...
