Mollox Posted March 15, 2003 Report Share Posted March 15, 2003 How do i do this and then how would I restore my backed up registry if need be? cheers inigo Quote Link to comment Share on other sites More sharing options...
danksy Posted March 16, 2003 Report Share Posted March 16, 2003 have you tried regedit, you can import and export, but i have never tried these options! Get a dos prompt Start>Run> Type "CMD" Then type regedit Then under File you can import, export! I have no idea other than this mate! Quote Link to comment Share on other sites More sharing options...
Hopsta Posted March 16, 2003 Report Share Posted March 16, 2003 onyl use regedit if you know what your doing !! it has no checking in it what so ever so you can delete to your hearts content Win98 is defaulted to take no backups of the registry, but you can amend this, see here To manually backup/restore use Scanreg from the run command. The cmd command wil only work with NT based systems 9x systems use 'command' Quote Link to comment Share on other sites More sharing options...
