Damp in footwell
Paley
Lifted passenger side front mat yesterday to find a soggy spot on carpet beneath. Not overjoyed, as you can imagine, but can find no obvious source of damp. The door seals seems to be fine. The drainage holes are not blocked under windscreen and there's no obvious water dropping down from behind the glovebox. Has anybody experienced this? If so, any obvious causes? Thanks chaps/chappesses.
  • 9 months later...
Hi, not sure if this is relevant but in the golf the window regulator seal was an issue and could leak. It would not be obvious as the drain holes would be unblocked etc and not apparently leaving marks on the side of the footwell. It would always show the water in the middle which is where it would collect. Not sure if the Audi's have the same style regulators but might be worth considering.
  • 4 years later...
My son has a vw golf gtitd1.9 its got water coming in front passenger side but lost of water rear passenger side on the near side tryed every thing seems like water is coming in throu under door seals i poured 2 cans of water down wind screen it came in so i found water runs down near front mud flaps took front wheels off one at a time took off mud flap and behind it was a load of muck cleaned it out both sides were full up resese seals washed out clean reasemebled and poured 2 cans of water none cane in the car after takeing out carpets and under felt to dry not put back yet time will tell if this is the fault with vws
