Munki Posted January 25, 2005 Report Share Posted January 25, 2005 So what are the widest wheels that will go on a passat? I am really tempted by these http://www.tyresmoke.net/ubbthreads/showflat.php/Cat/0/Number/325677/an/0/page/0/gonew/1#UNREAD but the standard tyres are 195mm wide and these are 255mm would they go without scraping the sides? Link to comment Share on other sites More sharing options...
R32North Posted January 26, 2005 Report Share Posted January 26, 2005 The tyres might fit but I think you'd be better off with the usual 225/40-18 tyres that are the right size for VAG cars, eg Golf, A3, Passat, etc. I don't know for sure but I think the alloys will be 8"x18" - can anyone confirm. What PCD and offset you got Munki? Link to comment Share on other sites More sharing options...
Munki Posted January 26, 2005 Author Report Share Posted January 26, 2005 I have whatever is standard. Thanks. All I know is that according to Rochford Tyres website it says 112x5 and 35-45. Looking on google a bit I found soemone say that he has 225 on the front and they run very rarely. However he had lowered it by an inch and a half. I think though that 10.8 inches instead of 8.5 might cause some grief. Anyone with a bit of thoughts / experience in this is still welcome to contribute though. Link to comment Share on other sites More sharing options...
R32North Posted January 26, 2005 Report Share Posted January 26, 2005 From VW you can buy aftermarket alloys, they are usually 7.5"x18" or 8"x18" and VW will fit 225/40-18" tyres as standard. You can put on 235/35-18 in order to keep the rolling radius as near as correct but it may rub if you lower the car. Offset would be 35-45mm, knowing the offest of these, I'm guessing at 38mm, would help to determine if there is potential for any issues. What size tyres you got just now, Munki? SDF Link to comment Share on other sites More sharing options...
jojo Posted January 26, 2005 Report Share Posted January 26, 2005 I have run 19 x 8.5 wheels, ET35 offset and lowered suspension on my Passat with 235/35s up front and 265/30s on the rear with no catching at all!, even when it's fully loaded up and the rear wheel sits right up in the arches - hope this helps. Link to comment Share on other sites More sharing options...
Rustynuts Posted January 26, 2005 Report Share Posted January 26, 2005 [ QUOTE ] I have run 19 x 8.5 wheels, ET35 offset and lowered suspension on my Passat with 235/35s up front and 265/30s on the rear with no catching at all!, even when it's fully loaded up and the rear wheel sits right up in the arches - hope this helps. [/ QUOTE ] And if you look very closely (you may find it helpful to use a magnifying glass) you can nearly see some tyre on those rims! Or are they rubber bands. Man, they're low profile! Link to comment Share on other sites More sharing options...
Munki Posted January 26, 2005 Author Report Share Posted January 26, 2005 Mmmmmm nice wheels..... At the mo I have the standard 15" but I have always liked the RS4 and RS6 wheels. My only worry is putting a 255 on the front. That is what I suspect will rub. Link to comment Share on other sites More sharing options...
jojo Posted January 26, 2005 Report Share Posted January 26, 2005 Well, that was 2 years ago, I'm currently running 18" RS6 wheels with the same suspension, as the replacement tyres I needed for the 19s was murder on my wallet, I have 19s on my S3 aswell The Passat seems to ride pretty well with the low profile tyres, probably because I'm running standard shocks, and it has handling to match my S3 in the dry. 255 tyres on the fronts is a big no no, 235s are mm's from catching the front arch on full lock. Here's a pic of my car with more rubber Link to comment Share on other sites More sharing options...
R32North Posted January 27, 2005 Report Share Posted January 27, 2005 Munki, you can get new RS4 Reps, 8"x18", with new 225/40-18 tyres for about £650 from quite a few places so you don't have to stress over those with the extra large tyres - check out some of the deals going about and I'm sure you'll get some that fit just fine Link to comment Share on other sites More sharing options...
jojo Posted January 28, 2005 Report Share Posted January 28, 2005 Here's a pic of my car with RS4's aswell Link to comment Share on other sites More sharing options...
Munki Posted January 29, 2005 Author Report Share Posted January 29, 2005 I thought that might be the case. I have looked at rochford tyres several times at the replicas but the thought of originals somehow seemed more tempting. I'll probably wait a wee while longer and get some RS6 replicas, I've always like them and I suspect they would be a tad easier to clean than the 4s. Thanks for the opinions. Link to comment Share on other sites More sharing options...
