malagus Posted January 26, 2005 Report Share Posted January 26, 2005 help! when I open MS access, a message appears "a problem occured while MS access was communicating with the OLE server or Active X control" I cannot install Access again (the wizard wont load) and I dont have norton. can you please help me! thx, Craig. Link to comment Share on other sites More sharing options...
Rustynuts Posted January 26, 2005 Report Share Posted January 26, 2005 If you have windows xp, you could try "system restore" and go back to a day when it last worked? Link to comment Share on other sites More sharing options...
A8_Tony Posted January 28, 2005 Report Share Posted January 28, 2005 Or check the microsoft support website, generally it's pretty good Have you changed your internet security settings recently, this is normally where any Active X control options are controlled! Link to comment Share on other sites More sharing options...
Jon Posted January 28, 2005 Report Share Posted January 28, 2005 Both suggestions are good, i really don't know much about Access unfortunately but you could try here: Web based type help Link to comment Share on other sites More sharing options...
Hopsta Posted January 29, 2005 Report Share Posted January 29, 2005 [ QUOTE ] Or check the microsoft support website, generally it's pretty good Have you changed your internet security settings recently, this is normally where any Active X control options are controlled! [/ QUOTE ] exactly Try this KB article M$ linky Link to comment Share on other sites More sharing options...
Sparky Posted January 29, 2005 Report Share Posted January 29, 2005 Have you told Access to use a Startup form? Sounds like it's trying to load a form you may have deleted or edited, or copied the Access DB from another computer to your own, which does not have the installed controls the other machine did. If it's doing this before it opens a DB, changes are the Startup form has been set. With Access closed, hold down your Shift key, double click on the Access Icon to run it, and only let go of Shift once it's fully loaded. Do you get the error then? Link to comment Share on other sites More sharing options...
