GTTDI Posted January 28, 2005 Report Share Posted January 28, 2005 Hi, I want to run 0 gauge power cable for my amplifiers but am a little unsure how people have done this? (Golf MK 4) Theres a grommet under the wiper tray thats just, just big enough to get 4 gauge through. Have people enlarged this hole, or drilled another? Or is there simpler way I've not yet found? Cheers, Link to comment Share on other sites More sharing options...
Tomk Posted January 28, 2005 Report Share Posted January 28, 2005 if the MK4 is like the A3 there is a gromit you can use behind the glove box that runs round the back of the engine, Link to comment Share on other sites More sharing options...
mattcony Posted January 28, 2005 Report Share Posted January 28, 2005 http://www.cs-media.co.uk/%7Ejames/vw/ice.htm cheers matt Link to comment Share on other sites More sharing options...
GTTDI Posted January 28, 2005 Author Report Share Posted January 28, 2005 [ QUOTE ] if the MK4 is like the A3 there is a grommet you can use behind the glove box that runs round the back of the engine, [/ QUOTE ] Hi thanks, have looked at that one it's just too small to get a 0 gauge cable through. [ QUOTE ] http://www.cs-media.co.uk/%7Ejames/vw/ice.htm cheers matt [/ QUOTE ] Cheers Matt, but believe that it is also too small for 0 gauge to pass through... Any more ideas please.... Link to comment Share on other sites More sharing options...
Tomk Posted January 29, 2005 Report Share Posted January 29, 2005 why you running a cable that large ? if anything take out that gromit and make the whole larger , Link to comment Share on other sites More sharing options...
mattcony Posted January 30, 2005 Report Share Posted January 30, 2005 You could get a bus through there !! As long as its been pre stabbed with a knife to cut the gromet, run a pre wire of average size 1st through the hole, then over lay the 0 gauge and the pull wire along side each other about 30cm then bind together with insulation tape very tightly. A guick spry with WD40 on the taped section and pull away from the engine bay and she will slide through easy job ! I ran 4 gauge in my R32 through that grommet and it would easily have taken 2 if not 3 runs through the same hole cheers Matt Link to comment Share on other sites More sharing options...
GTTDI Posted January 31, 2005 Author Report Share Posted January 31, 2005 Excellent, going to head out and give it another go, cheers for all the tips guys Link to comment Share on other sites More sharing options...
