Have I a faulty MAF?
Paullorman
Hi all,
After my recent purchase of VAG-COM I think my MAF may be faulty. I bought VAG-COM to see if I could see why my idle is slightly lumpy, both when cold and warm. Having a 2001 A6 4.2 V8, I would have thought it would be smooth as silk but when idling at ~600rpm, you can feel a slight shudder.
Upon connection I find the following codes
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4D0 907 560 H
Component and/or Version: 4.2L V8/5V G 0001
Software Coding: 05752
Work Shop Code: WSC 02325
2 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-10 - - - Intermittent
Reading the excellent tech article on fuel trim by andy@Ross-tech, Fuel Trim
I looked at the fuel trim settings. These are as follows:-
-2.4% 22.7% -2.4% 21.1%
I have also performed a second gear full-throttle run to measure the air mass. The maximum figure I achieved was 159 g/s As I am supposed to have 300bhp, I believe the top figure should be around 240 g/s.
Could someone with greater knowledge than I confirm that it appears my MAF is faulty? I have been given a price for a new MAF of £210 ($375) however, the car is still under Audi warranty! Has anyone got any ideas how I can get Audi to pay for this? I am not sure how I can convince Audi my car has fault codes!
Thanks in advance!
Paul
Tom MAF's dont generally bring up dault codes, which is why you have to compare the figures. The MAF is constantly measuring air flow across a range so as long as the figures are within that range it'll think its ok, so it cant recognise that its wrong until its very bad. I hope you understand what I mean. crazy.gif
Paul from the figure you have quoted it does indeed seem that your MAF is faulty, the only real way around it is to replace it. Audi should cover it under the warranty, and I have known of them doing it under warranty on other cars so they should know what you are on about. I would quote the figures that you have measured to them, all the dealers would know what VAG-com is and in my opinion would not try and fob you off as you know what you are on about. 169144-ok.gif
Just checking you do have the standard air filter dont you?
Just disconnect it and run the car. The engine will take its readings from other engine sensors, then reconnect.
This may well throw up a MAF relted code that the dealer can see and will compound the theory that it's knackerd.
This certainly works with late S3's.
Cheers
Ben
  • 2 weeks later...
I've been wondering whether my MAF has gone west. Performance seems to vary a bit, there's occasional hesitation and, although it may just be my imagination, the engine note seems a little gruffer.
Finally got round to opening the bonnet and unclipping the MAF lead last night. Took it for a short run and wasn't quite sure. There seemed to be more consistent boost, the car seemed a bit keener and sounded a little 'zingier' (less gruff to you and me!).
Although i might just have been wanting to feel that. It really is hard to tell.
Tried it with the MAF back on and it was a bit jerky coming off the throttle which was a little odd. Didn't really have more than 3 mins to try it with the MAF again so will do a longer run including motorway on...oooh its Valentine's tonight, wednesday I suppose. And we will see...
Mollox you can always log it with vag-com.
a quick blast up the road, will log its peak Grams/sec
a breathed on S3 should be getting around the 190+ g/sec at peak rpm
Ive used it to check mine in the past.
tho i am not so confident with the boost actual vs requested
Popped out for a minute earlier. Strange things happened. The car was very cold and moving out of my space the engine was making a wheezing sound each time I went to move and then the revs would surge to 1800 rpm then drop. Idle was around 1200 too which was wrong.
It was doing it repeatedly so I stopped, checked the connection on the MAF, a bird shat on the roof, I was angrier, and then tried again. Same thing so I thought I'd drive it gently and let it warm up. Once warm it didn't do it. I'll have to check it again from cold tomorrow.
Odd - its never not idled properly in 4 years and then this....
Phew, seems fine again (i'd do a smiley but they're broken).
Seemed faster again tonight. Think I'm going to pop on a new MAF as a precaution. Might wait for Sunday to datalog MAF values but then again I might just get it done before so I can be right for the RR day. Decisions.
This little episode has reminded me how just much of an effect a MAF has on a turbo'd car...
Just to let you know... my new MAF FINALLY arrived; £213 from VAG. Changed it in 10 mins (would have been 5 if Audi had not been daft enough to put the two bolts that hold it on at 12 and 6'O Clock position). Went for a spin, no fault codes, fuel trim perfect, correct breathing 243g/sec.
Problem solved :-D
