branchespark Posted January 31, 2005 Report Share Posted January 31, 2005 Would love it if anyone could help! 1. As my new allroad has the DVD RNS-E system, does that mean the car is CAN-BUS equipped, or is it just for the sat nav? 2. Are there any CAN-BUS adapters for using other car kits (or RoadPilot) that requires a switched feed? Alternatively, where do I find a switched feed for my kit?! 3. Does anyone know if it is possible (or the part numbers) for the bluetooth module for the RNS-E that is in the new A4? Cheers. Link to comment Share on other sites More sharing options...
alarming Posted January 31, 2005 Report Share Posted January 31, 2005 1.Yes the car does use the can bus system the RNS-E is treated a complete module 2. A company called Dietz make can bus adapters Clicky But i don't think you will need one if all you want is a switched voltage. If you remove the large foot well panel under neither the steering wheel a row of bolt type terminals connectors can be found. There is a switched voltage here which I think has a black/yellow cable connected to it all the others are permanent live from memory and have red cables going to them. 3. No idea, I used the Nokia Nokia CK-7W Bluetooth kit and I’m happy with results Good Luck Link to comment Share on other sites More sharing options...
