A4 tyre pressures.
Waylander
on 18"s i run 36 front and 34 back.
I tested higher and lower pressures....
more than 37 at the front and the inner part wears quicker than the outer, so 36 seems about right.
same test for the rears. and rears should usually be a lower pressure as less weight and no power steering.
but my pressures on the cab, which are 200kg's heavier
do you have 3/4 passengers and a full boot all the time then?
you need to check the wear isnt just at the centre of your tread otherwise they'll wear out prematurely.
the recommended pressure for mine (on the A-pillar) is 42.
thats way too high for everyday use, the tyres would be dead after 10K miles.
