willg60 Posted February 22, 2005 Report Share Posted February 22, 2005 hi, my electric ariel started making a bad noise like metal cogs grinding? It still goes up and down but only about half way then makes this noise! is it knackered? easy to replace? Link to comment Share on other sites More sharing options...
Stuey Posted February 22, 2005 Report Share Posted February 22, 2005 hi, mine will only go up and down with some extra help (ooer). I have been trying to get a 2nd hand one for ages but with no luck I have been quoted around £88 + vat from vagparts.com I'm starting to think about replacing it with a simple bee sting aerial. Unless it can be serviced? Link to comment Share on other sites More sharing options...
carlos50 Posted February 22, 2005 Report Share Posted February 22, 2005 Do the electric ariels fit an S8 ?. Mine has the fixed type on the rear quarter and the electric one sounds nicer.£88 is a lot though so its just a thought at the moment. Link to comment Share on other sites More sharing options...
Ska Posted February 22, 2005 Report Share Posted February 22, 2005 £88 compared to £138 from the stealer...hmmm...I'd go for it! Unfortunately I've been told that the original audi unit is the only thing that fits the A8/S8 quater panel. How true that is I dont know cos it was the stealer who said it in the first place. Link to comment Share on other sites More sharing options...
Stuey Posted February 22, 2005 Report Share Posted February 22, 2005 that £88 needs vat sticking on top of it, so that works out around £103.40, then theres the £8 postage to plonk on top. Does anyone know if the universal electric aerials will fit? Link to comment Share on other sites More sharing options...
cruiser647 Posted February 22, 2005 Report Share Posted February 22, 2005 Hi, the ariel is made to fit an aluminium car. Soooooo you have to be careful, as you might start corrosion if you use a standard electric one with steel fittings.......... Hence the stealer can charge a lot. Be careful on this. Link to comment Share on other sites More sharing options...
msey Posted February 22, 2005 Report Share Posted February 22, 2005 Hi there. I replaced my electrix ariel with a Hirschmann Electric one. Hirschmann make a range of ariels. The one that I fitted was £38 from EuroCarParts.com. Note sure on your model. Mine is a 97 4.2 QS. I kept the plastic bubble that the ariel fits through on the rear quater panel. This is the part that attaches to the outside panel. Hope this is of help. There should be an old post where i listed the part numbers. Link to comment Share on other sites More sharing options...
willg60 Posted February 23, 2005 Author Report Share Posted February 23, 2005 yep, mine is a 4.2 QS too (1995), was it easy to fit? Link to comment Share on other sites More sharing options...
PaulW Posted February 23, 2005 Report Share Posted February 23, 2005 Here's a procedure: http://www.audipages.com/Tech_Articles/electrical_equipment/antennaremove.html Link to comment Share on other sites More sharing options...
msey Posted February 24, 2005 Report Share Posted February 24, 2005 Yep it was easy to fit. Link to comment Share on other sites More sharing options...
Stuey Posted February 24, 2005 Report Share Posted February 24, 2005 Just ordered mine from www.eurocarparts.com Part number 931770070. £40 something including delivery. Link to comment Share on other sites More sharing options...
Ska Posted February 25, 2005 Report Share Posted February 25, 2005 thanks for the part no. I grab one from the branch in west london today. Link to comment Share on other sites More sharing options...
