robb1977 Posted February 22, 2005 Report Share Posted February 22, 2005 HI ive got a 1999 2.0 golf gti and when accelerating the cars seems to judder between 2000 and 3000 revs, once above 3000 revs the car seems fine. Any ideas please Link to comment Share on other sites More sharing options...
robb1977 Posted February 22, 2005 Author Report Share Posted February 22, 2005 The car seems to be doing it all through the revs now, it seems hesitant then accelerates ok Link to comment Share on other sites More sharing options...
shao_khan Posted February 22, 2005 Report Share Posted February 22, 2005 Hi, welcome to Tyresmoke. We have a couple of Tech Gurus around the VW forums so you should get an answer soon enough. Link to comment Share on other sites More sharing options...
robb1977 Posted February 23, 2005 Author Report Share Posted February 23, 2005 just checked the oil and theres some "gunge" on it, could this be anything to do with it Link to comment Share on other sites More sharing options...
Rustynuts Posted February 23, 2005 Report Share Posted February 23, 2005 Rob, I'm sorry, I know nothing about the petrol version of the VW's. Now, if you'd bought a diesel, I might be able to help, but it's all too different for me I'm afraid. Tobes is the man for you but he's out of the country right now, and only sticks his face in now and again. Stick around and see if he pops in. Cheers. Link to comment Share on other sites More sharing options...
robb1977 Posted February 23, 2005 Author Report Share Posted February 23, 2005 Thanks anyway Link to comment Share on other sites More sharing options...
R32North Posted February 24, 2005 Report Share Posted February 24, 2005 Gunge... as in creamish sludge in the cap or on the dipstick. This is 'mulsification' or when water and oil are mixed!! Should cause the car to judder tho, but I can't really comment as I din't know what kind of judder you are on about. I've taken from what you've said that its not a wheel / speed related judder and so must be an engine or gearbox judder. It is a fast or slow judder, is it deep or soft or loud or quiet? All info helps! Also, can you try to slipping the clutch thru the rev range to see if this makes it worse or better? Post again when you know more !! SDF:) Link to comment Share on other sites More sharing options...
robb1977 Posted February 24, 2005 Author Report Share Posted February 24, 2005 ive just checked my car and my mate says its misfiring, tried disconnecting the MAF but that didnt help. the car seems to hesitate then accelerate, i tried dipping the clutch but that doesnt seem to do anything, the cars just had a 60000 mile service. Link to comment Share on other sites More sharing options...
mowgli Posted March 4, 2005 Report Share Posted March 4, 2005 Robb, have a look here: http://www.forum.golfgti.co.uk/index.php?PHPSESSID=c116a391f93b708b16faa2df0aae20ad&board=8.0 Yours is the same engine as in the MK3, so the fixes should be the same. Good luck Link to comment Share on other sites More sharing options...
andrew006 Posted March 4, 2005 Report Share Posted March 4, 2005 My golf diesel had a similar problem.It sounded as if it was dropping a cyclinder when idling and then would judder until the turbo kicked.The solution from vw was to change the ecu but also to clean out the throttle body+ throttle body position sensor. Link to comment Share on other sites More sharing options...
Rustynuts Posted March 4, 2005 Report Share Posted March 4, 2005 I don't think you had a Diesel with a throttle on it, did you? Link to comment Share on other sites More sharing options...
