simonlewin Posted February 22, 2005 Report Share Posted February 22, 2005 Hello, I have a 2004 Allroad 2.5Tdi with 15,000 miles on the clock. A couple of months ago I noticed that there was a bit of vibration felt in the front and steering wheel between 75-80mph (i.e. you can drive 'through' the vibration) I took it to ATS who balanced the front wheels. This didn't make any difference. Then someone mentioned that as it's 4WD, maybe the rear wheels should have been balanced too. I was going to take the car into Audi next week so they could look over everything but passed ATS today to see if they could double check the rear wheels. They had a look and reckon the problem could be down to wear - apparantly there's some 'feathering' and the tread is down to 2mm (and 1.6mm is the legal minimum). They've recommended a new set of tyres for 600 GBP all in and reckon that with wheel balancing etc. it'll feel as new. I'd been warned about the speed with which an Allroad gets through tyres. The guys at ATS have been very helpful - I just wanted to double check all of this seemed to make sense and that the cost doesn't seem way too high. Any comments appreciated! Thanks Simon Link to comment Share on other sites More sharing options...
Daz Posted February 22, 2005 Report Share Posted February 22, 2005 £600 sounds well cheap for 4 allroad tyres, they are normally between £200 & £250 each. Make sure that they are supplying proper allroad tyres. I had a similar vibration on my allroad after I had a new tyre fitted to the rear. Make sure all 4 tyres are balanced properly. Link to comment Share on other sites More sharing options...
grahamb Posted February 24, 2005 Report Share Posted February 24, 2005 Change the tyres! I had a bad virbation which was uncurable using a balancing machine. I had to change one of the fronts for the MOT (worn on the outside edge) and its cured the problem. Its a nice car to drive again. My replacement tyres are going to come from www.blackcircles.co.uk Link to comment Share on other sites More sharing options...
spacehunter Posted March 1, 2005 Report Share Posted March 1, 2005 Try having your tracking seen to. Link to comment Share on other sites More sharing options...
seadweller Posted March 2, 2005 Report Share Posted March 2, 2005 Hi Think ours were sub £600, but I would have to confirm that with the Mrs We went for the Pirelli's (as oposed to the Goodyears that were on there) as they look a lot wider, cannot help much with milage as we had to have two new ones following an accident. We had to have new discs (under warranty after a tussel!)on ours too, as the originals warped after 12-18 months Hope this helps Link to comment Share on other sites More sharing options...
simonlewin Posted March 3, 2005 Author Report Share Posted March 3, 2005 Just to let you know that with 4 new Pirellis on (£600 inc. fitting from ATS) the car's running better than ever! This episode also reminded me that as the rubber's the bit that touches the road, it's well worth keeping an eye on the quality. Cheers, Simon Link to comment Share on other sites More sharing options...
Daz Posted March 3, 2005 Report Share Posted March 3, 2005 Well done, that's an excellent price for them Link to comment Share on other sites More sharing options...
Cerberos Posted March 27, 2005 Report Share Posted March 27, 2005 Been searching for tyres recently and came across this Etyres GOODYEAR - WRANGLER F1 225/55R17W 4X4 The new Goodyear Wrangler F1 VWZ rated tyre perfectly suits powerful 4x4 vehicles, offering speed, style and safety. <font color="red"> £119 inc VAT fitted </font> And they come to you to fit them. Has anyone used etyres? Are they available in all areas of the UK? Link to comment Share on other sites More sharing options...
