paul130TDI Posted February 23, 2005 Report Share Posted February 23, 2005 this might sound like a stupid question, but where is the handbrake adjustment on the A3's with disc brakes. I took the wheel off and cannot see any means of adjustment, does the handbrake work off the rear brake pads or is there small shoes within the back hub? Cheers Paul Link to comment Share on other sites More sharing options...
Tomk Posted February 23, 2005 Report Share Posted February 23, 2005 i think you need to take the rear ash tray out from behind the centre concel, it just pops out from memory and think the adjuster is there ! will only take a sec to check, Link to comment Share on other sites More sharing options...
paul130TDI Posted February 24, 2005 Author Report Share Posted February 24, 2005 Cheers, Is there any means of adjustment at the wheels as is the case with drum brakes. My previous car had disc brakes but also had a small drum and shoes in the center of the hub which the handbrake worked off. Does anyone know if the A3 handbrake works off the rear brake pads and if this can be adjusted. Cheers Paul Link to comment Share on other sites More sharing options...
