grahamb Posted February 24, 2005 Report Share Posted February 24, 2005 Noticed at the MOT last week that the plastic undertray has a lot of oil on it, and as I've never layed a spanner on the engine (always serviced by stealers) whats the most likely gasket to have gone? When I pull up at a junction I can smell burnt old oil. She's done 96K Link to comment Share on other sites More sharing options...
Edd_W Posted February 24, 2005 Report Share Posted February 24, 2005 the leaks can be caused by the vacuum assister becoming blocked up internally. It is a venturi device inbetween the rear of the LH head and the back of the inlet manifold. It has about three pipes connected, one onto each end and one smaller off the side. The hoses are crimped on so to test it you have to cut them off. There are one-way valves inside it so the air will only flow one-way. There is loads of info on this here http://forums.audiworld.com/a6/msgs/486032.phtml Link to comment Share on other sites More sharing options...
grahamb Posted February 27, 2005 Author Report Share Posted February 27, 2005 Thanks, I'll take a look Link to comment Share on other sites More sharing options...
