Sony shows off new PlayStation 3
Sparky
Sony has unveiled its new PlayStation 3 console, calling it "a supercomputer for computer entertainment".
The console is powered by a powerful new processor dubbed Cell, which Sony says is 35 times faster than the chip inside the current PlayStation.
Twice as fast as the new Xbox 360
CPU Cell Processor running at 3.2Ghz with 2.18 teraflops of performance
Backward compatible
256Mb XDR main RAM at 3.2 GHz
256Mb of GDDR VRAM at 700Mhz
Memory Stick Duo, SD, compact flash memory slots
Detachable 2.5 inch hard drive
Support for seven Bluetooth controllers
Six USB slots for peripherals
Supports Blu-ray DVD format
Output in HDTV resolution up to 1080p as standard
Linky
dont fall for that one Sparky...graphics performance is mainly down to the co-pros, ram speed and bus speeds. dont fall for a silly cpu benchmark.
there's a reason that the xbox I only has a 700mhz cpu .... it does feck all!
Specs on the new PS3 look might impressive which ever way you look at it.
A very powerful Cell chip with 8 engines - 7 in use and 1 for redundancy.
The Graphics engine as Chav says is more important, so hows about it is more powerful than 2 6800 Ultra Nvida PC cards combined. Now I don't know about you but that is some raw power. Throw in that it will fully support HD TV and things are looking great for the consumer. Considering that power would cost you £600 alone at the moment and the console itself could look very cheap indeed when you look at the specs. Memory access speeds also look very heathy when you compare them with a PC thats for sure.
Will have to see what its like head to head with the Xbox 360 and what the developers can come up with. Either way things are looking very good indeed. 169144-ok.gif
  • 2 weeks later...
