[Audi A3/S3] Air bag fault code
Rusty
Hi folks,
My car developed an airbag problem today and on connecting VAGCOM to the car it registered a 65535 fault code.
Does anyone know if this can be reset at the dealers or do I need a new one?
Does anyone know where I can get a new Airbag module?
(P/N 8L0 959 655 J)
Cheers
Rusty
hi mate,
that code rings a bell, and also airbag problems when scanning with vagcom, although it appears to be a VW issue with a different controller part number.
however...
We have had a number of reports of Air Bag Warning Lights staying on permanently after scanning with VAG-COM. The Air Bag Controller shows DTC number 65535, indicating an internal error which cannot be cleared.
regardless of wether this code was created by scanning, or if it was already there , it appears its not one that can be cleared. smashfreakB.gif
Ross-Tech Source
www.vagparts.com maybe able to help you with parts if you need a new one. Their website only shows a fraction of what they retail.
Thanks for the info. After I posted the article I done some more digging into this issue and found the same info on Ross-tech.
When looking at ETKA it appears that the control module is located below the centre console.
Does anyone know if this is easy to remove and how it is removed.
Can I run the car if the Airbag controller is removed from the vehicle and is there anything needs done with VAGCOM to change the controller.
Cheers
Rusty
